Phone on and off
Kinguska89
Visitor
Phone on and off
My phone is still switching off and on without reason. I bring back all factory settings and is not working. What i should do with that?
7 REPLIES 7
Uliwooly
@Kinguska89
Does this happen as soon as you turn on the phone OR after you use it?
Kinguska89
Visitor
I can't even used I tried to press any off app is stops and switch off... And after few second automatically switching on by himself.
Uliwooly
@Kinguska89
Remove the SIM and SD cards > boot in >>> safe mode  > see if you experience the same issue
Kinguska89
Visitor
Is without SIM card and SD card and is doing like that
Uliwooly
@Kinguska89
Have you repaired the phone with Xperia Companion or did you performed a factory reset through the phone's settings menu?
Kinguska89
Visitor
I made second option. First i don't know what is that this xperia companion.
I have first time like that and really I don't know what I need to do
profile.country.PL.title
najodleglejszy
@Kinguska89here's a tutorial for performing a repair with Xperia Companion /t5/FAQ/How-to-perform-a-software-repair-with-Xperia-Companion/td-p/1103057
