My phone is still switching off and on without reason. I bring back all factory settings and is not working. What i should do with that?
I can't even used I tried to press any off app is stops and switch off... And after few second automatically switching on by himself.
Remove the SIM and SD cards > boot in >>> safe mode > see if you experience the same issue
Is without SIM card and SD card and is doing like that
Have you repaired the phone with Xperia Companion or did you performed a factory reset through the phone's settings menu?
I made second option. First i don't know what is that this xperia companion.
I have first time like that and really I don't know what I need to do
@Kinguska89here's a tutorial for performing a repair with Xperia Companion /t5/FAQ/How-to-perform-a-software-repair-with-Xperia-Companion/td-p/1103057
