Hi. My Xperia Z3 compact doesn't recognize the sd card. It started happening suddenly. The card can be read on other devices. What can i do ?
Solved! Go to Solution.
Test a different SD card with your phone and report back.
Also might be worth testing the card with h2testw software on a pc
Well... It started working again suddenly. I think maybe it was wet Thank you anyway!
Anytime
