When Marsmallow didn't have stamina I used to get 3-4 full days with no problems (only on doze). Now, with latest update I am getting almost 1 and a half day tops, with same usage, settings and apps.
It is a fact that stamina on Z1 and Z3 compact are performing better than on Z5 compact.
guys i'm confused i purchased z5 premium dual sim and im now on 5.1.1 OS
battery life is decent i get 3:30 to 4 hrs on screen time using and almost get through the day
i want to upgrade to android 6 but i read alot of negative comments regarding it
i need your advice if i upgraded to 6 is better for performence and battery life or it is going to be worse
so i will make it simple does t worthy this upgrade or i have to stay on android 5.1.1 better for me
you support highly appreciated
You don't have to create a new thread
@Ahmed1986 wrote:guys i'm confused i purchased z5 premium dual sim and im now on 5.1.1 OS
It 's like asking how you take a bottle of water . Depending on how much you're thirsty . In any case make sure that after upgrade you do factroy reset . In my case ( I did not use stamina and i'm getting is almost the same thing)
I called Sony Germany today. They don´t know when and if an update will come. They are addicted to Google. If an update is coming it will not be an original Sony Stamina Mode. It will be Google Doze again.
The only way to get Stamina back is to downgrade to 5.1.1. They are claiming warranty will be lost but german courts decided already it will not be lost.
You can also get a part of your money back, because it will not have the same features after an update, but without there will be security problems. It is the same like you buy an V8 Mercedes and a year later Mercedes comes, changes your engine to a normal 4 cyl.. Of course, that will not happen, but Sony does so to their Xperia Consumers regarding to Android 6.
If you do not unlock bootloader and just flash STOCK Lollipop firmware then everything is ok for the warranty.
From XDA you can get (most probably) the correct firmware for your region. Beside that, use flashtool.
