¿Cómo limpian la pantalla del XZ premium? Se puede usar algun líquido o solo una microfibra seca? De vez en cuándo queda muy manchada la pantalla del XZ y un paño seco no logra limpiar perfectamente la superficie.
How do you clean the XZ premium screen? Can you use some liquid or just a dry microfiber? From time to time the XZ screen is very stained and a dry cloth can not clean the surface perfectly.
GT
Solved! Go to Solution.
Using Carl Zeiss Lens Wipe works best for me.
It doesnt damage the oleophobic coating.
Hi @Chromium64z
Welcome to the community!
We would only suggest using a clean, dry, lint free cloth to clean the screen of your device as you have been doing.
Using anything else could cause damage or make its way to the internals of the device and cause issues.
@Chromium64z i have had many, many mobiles over the years....have always used a cleaning fluid that is designed for cleaning screens, but often as mentioned a soft buff with a good quality microfibre cloth is best......have never ever 'washed' it under running water & really can't fathom the mentality of doing so.....but that is my opinion :smileysmileywink:
"washed" it under running water.... Hahahaha...
