Xperia Play charging problems
Not applicable
I used to have a Xperia x10 and it had broke three times in regards to charging (I plugged it in and it would only charge at random times) this happened three times the first time I bouight the phone to the carrier and they repaired it, the second time as it broke again within a month so it got replaced and the third time I decided to get it repaired and then sell it on mazuma. In replacement I naivley bought anohter Sony ericsson thinking that it would not be a reoccuring problem but now I have the same problem with the Xperia play. It's not the battery, I've tried another battery, It's not the wire I have a close friend who is an electrician who checked out the face plate and the wire. Any suggestions? 😕
16 REPLIES 16
Not applicable
how will i know if my xperia play is already fully charged?
Uliwooly
it's easier to get faster answers and/or more participation on a new thread
now, you can NEVER over charge your battery, UNLESS you install a custom ROM, so once it gets to 100% it will stop charging
HwaA18
Visitor
NOT TRUE!!!!!!!!! I have overcharged my r800x, and the battery has gotten obviously worse.
Sam
Legend
Legend
Not sure how you managed this as Uliwooly is 100% correct. Can you please clarify how you have come to this conclusion?
What are your thoughts about this forum? Let us know by doing this short survey.
HwaA18
Visitor
Um read this post by me.http://talk.sonymobile.com/thread/34007
HwaA18
Visitor
also I can tell by an app battery graph and when it reaches 100, it stays 100
sonymaster1
Visitor
I have had the same problem with my xperia play i switched it off device then tricked the system by turning on while usb plugged in the whole time hope this helps Slightly_smiling_Face
