TIPO TOUCHSCREEN FIX PATCH HERE
mambroa
Visitor
FIX FOR THE TOUCHSCREEN PROBLEM::smileylaugh::smileylove:
METHOD 1: INSTALLING THE .APK FILE FROM SD CARD
1-Download the file from http://www.4shared.com/rar/3p6YulVl/ST21i_calibrate.html
2-Unpack it and copy the .apk file to your SD card (THAT CAN BE FOUND IN THE "TOOLS" FOLDER)
3-Install it using Easy Installer (that you can easily download to your handset with google play)
4-Run the tool, put your phone in a plain surface and click the button "calibrate" (there will be only one button in the middle of the screen).
The phone will get fixed right away, and you may uninstall the so called patch.
METHOD 2: INSTALLING VIA WINDOWS (SEEMS EASYER, DON'T KNOW IF IT WORKS):
1. extract it to somewhere in your PC
2. connect your Tipo to PC
3. open tool folder and run adb_detect.bat
4. run setup_TouchFWTools.bat
5. disconnect your Tipo and you will see the callibration option on your Tipo screen
6. put your Tipo on the table or something that have flat surface and start callibration
7. tadaaa.. your tipo will run smoothly now.. tested by BLINDSHOOTER..
It shall work for Sony Xperia Tipo ST21i, Sony Xperia Tipo ST21a, Sony Xperia Tipo Dual ST21i2, Sony Xperia Tipo ST21a2, and other models that have the same issue, such as Sony Xperia Sola and Sony Xperia Miro
This patch was first released at XDA by user blindshooter at post:
http://forum.xda-developers.com/showpost.php?p=33782261&postcount=347
Comments:
This is a so-called "calibrator", but it makes no calibration at all, it just patches the phone. It is obviously made by Sony, but somehow they did not gave it away, who knows why?
For those that are not familiar with this million-users defect, this patch / fix will work for sony xperia phones with the laggy touchscreen, as described in this thread:
http://talk.sonymobile.com/thread/53679
I hope you did not throw the phone away, after you apply the patch it gets pretty good.
THANK YOU USERS COMMUNITY!
Message was edited by: mambroa
56 REPLIES 56
prashanth
Visitor
wowow.. its really amazing, it worked actually.. my Tipo is silk smooth now..
Thanks and thanks and thanks a ton.. Slightly_smiling_Face
MJC
Visitor
You are welcome
FYI, I uninstalled the app and the screen still works ok.
I don't like running applications that don't come from Sony or Google play.
I stored the app on my external (32 gig) SD card, and I will reinstall it if the problem comes back ... which I assume will happen if I reset the phone.
Sony really, really should issue a patch for this problem!!!  This is really a great phone for the  price.
MJC
nickjohn
Visitor
Thanks! Read an article here that fixed the touchscreen issue. http://www.josephcs.com/blog/fix-android-touchscreen-issues/
Almost the same steps I guess.
@MJC To be cautious, you could also check the permissions that the app has access to.
aseem_nigam
Visitor
thanx a lot man..!!!
jho1986
Visitor
Resolveu meu problema!! Muito obrigado, excelente tutorial!!
Thank's man!!
gbhatt
Visitor
thank you....thank you...thank you....i install the patch using method 2.....I feel lucky today...thanks man
HaiUlahSky
Visitor
Go to http://www.4shared.com/android/WVUmBpm_/TouchRecalibrate_Strmobile_Exp.html
1. Copy to memorycard
2. Open file manager goto your save file or goto Aplplicasi instal
3. Instal Applicasi TouchRecalibrate.apk
you can calibration your Sony Experia Slightly_smiling_Face
Augusto
Visitor
You sir are a genius and a god! Thank you so much for fixing everyone's touchscreen problems, including me! :smileygrin:
Bazilio
Visitor
It works!
Thank you!
sherift
Visitor
my tipo was upgraded with cm10 .I try to install this apk but it says application not installed.
please help me.
