TIPO TOUCHSCREEN FIX PATCH HERE
mambroa
Visitor
FIX FOR THE TOUCHSCREEN PROBLEM::smileylaugh::smileylove:
METHOD 1: INSTALLING THE .APK FILE FROM SD CARD
1-Download the file from http://www.4shared.com/rar/3p6YulVl/ST21i_calibrate.html
2-Unpack it and copy the .apk file to your SD card (THAT CAN BE FOUND IN THE "TOOLS" FOLDER)
3-Install it using Easy Installer (that you can easily download to your handset with google play)
4-Run the tool, put your phone in a plain surface and click the button "calibrate" (there will be only one button in the middle of the screen).
The phone will get fixed right away, and you may uninstall the so called patch.
METHOD 2: INSTALLING VIA WINDOWS (SEEMS EASYER, DON'T KNOW IF IT WORKS):
1. extract it to somewhere in your PC
2. connect your Tipo to PC
3. open tool folder and run adb_detect.bat
4. run setup_TouchFWTools.bat
5. disconnect your Tipo and you will see the callibration option on your Tipo screen
6. put your Tipo on the table or something that have flat surface and start callibration
7. tadaaa.. your tipo will run smoothly now.. tested by BLINDSHOOTER..
It shall work for Sony Xperia Tipo ST21i, Sony Xperia Tipo ST21a, Sony Xperia Tipo Dual ST21i2, Sony Xperia Tipo ST21a2, and other models that have the same issue, such as Sony Xperia Sola and Sony Xperia Miro
This patch was first released at XDA by user blindshooter at post:
http://forum.xda-developers.com/showpost.php?p=33782261&postcount=347
Comments:
This is a so-called "calibrator", but it makes no calibration at all, it just patches the phone. It is obviously made by Sony, but somehow they did not gave it away, who knows why?
For those that are not familiar with this million-users defect, this patch / fix will work for sony xperia phones with the laggy touchscreen, as described in this thread:
http://talk.sonymobile.com/thread/53679
I hope you did not throw the phone away, after you apply the patch it gets pretty good.
THANK YOU USERS COMMUNITY!
Message was edited by: mambroa
56 REPLIES 56
aa_pratomo
Visitor
thank guys, this patch was help me :smileylaugh::smileyhappy::smileysilly:
linear
Visitor
It worked! Many thanks man!!!!
Just a note: Method 1 worked perfectly. Method 2 didn't work for me. The program didn't recognize my phone.
vnxx
Visitor
Does this work for Sola?
Praveenseven
Visitor
It worked me too ! Many thanks man!!!!
Method 1 ,
now its my tipo dual is like silk touch..
AmithSPuthoor
Visitor
Thankz For the Patch Slightly_smiling_Face
MY TIPO's TOUCHSCREEN PROBLEM SOLVED :smileygrin:
Itz Working Fine Now Smiling_Face_with_open_mouth_&_closed_Eyes
LukasK
Visitor
thanks man Slightly_smiling_Face
nicks1008
Visitor
thanks a ton Slightly_smiling_Face
Finally its a silky smooth ...  hushhhh !!
raushanrox
Visitor
  • I downloaded the file from  http://www.4shared.com/rar/3p6YulVl/ST21i_calibrate.html in mobile Sony Xperia tipo dual (ST21i2).
  • Copy in to PC and unzip it. (getting trouble to untar in mobile).
  • Goto-> tipo-> tool-> then copy "TouchFWToolsAP_Sony-Ericsson-JDM-Platform-Signing-Live-54f9-3.apk" to mobile
  • install this on your mobile.
  • put your mobile in a plain surface and click the button "calibrate".
  • It worked 4 me. Slightly_smiling_Face
Saran
Visitor
I did not had any issues with touch, But after installing I found some smooth touch interface ... did any one noticed it.
