I have a beautiful VGN-TX3XP, which I havent't used in ages. With the advent of the netbook craze, I forsook the VAIO in favour of an eee PC, sounds crazy, but it's true.
Now I have to use the VAIO again, and I have found that the battery, which was one of the wonderful things about it, is more or less on its knees. I had stored the VAIO with the battery out of the chassis, which I was told was the right thing to do, but while I used to get up to 6 hours life out of the thing, I now get barely 3.
Is there something I can do about this? Just keep using and re-charging until full life is regained? Or do I have to accept that the battery has died, and I must find a new one?
If I have to find a new one, is there a recommended aftermarket for this sort of thing?
thanks for any help
rjstep3
unfortunately you can't ...
Over time, the actual battery capacity decreases due to electrochemical inefficiencies within each cell. This loss in capacity (aging) is irreversible; it cannot be restored by cycling the battery. Gradually, less and less active material is available within each cell to electrochemically store a charge. Consequently, is normal to experience reduced computer run time.
I don't recommend buying aftermarket batteries since most of them are low-quality and might be dangerous (catching fire).
Sony also started to check the authenticity battery on the new VAIOs to prevent accidents.
that was the news I was fearing, but thanks for the posts, it's better to know.
rjstep3
