Solved! Go to Solution.
The screenshot button has been removed from this firmware, so like rest of us (and some other Android based units), you only have one option: press together Power button + Volume Down button
after update my xperia sp, no screenshots at on / off button...y?
It has been removed,now you need to use a combination of keys: power button+vol down at the same time.
No... this not work :////
It should work.
If I knew this option would disappear from power button, i wouldn't update it. i use a lot that functionality and i wonder why they removed it. It is my own opinion but i prefer to use the power button than pressing on two buttons on same time. Anyway we will get used to it. But I will not run the updates anymore as I do not want to have surprises.
It works,use two fingers.
