Speaker Extension Cable for BDV-EF200
SOLVED
profile.country.en_GB.title
kjharve
Visitor
Hi all,
I recently bought a Sony Blu-Ray Home Cinema System (BDV-EF200) but the cable is too short on the speakers. I've trawled eBay and Maplin but can't find any extension cable or connector to do the job.
Does anyone know if these are available? If so, what should I be searching for as I've had no success so far.
Here's an image of the jacks.
Cheers,
Kevin
1 ACCEPTED SOLUTION
Accepted Solutions
Bravia55HX
Member
easiest way is to buy some speaker cable from the likes of maplins and splice it in to the wires you have, you an twist and tape the joins with electrical tape, you can also solder the joins if your feeling confident enough, failing that, find someone willing to do the work for you.
2 REPLIES 2
kjharve
Visitor
Any ideas?
Bravia55HX
Member
