Built In WiFi problem
SOLVED
profile.country.IE.title
Poc260779
Explorer
Hi
I recently bought a XF438505 Sony android tv. The WiFi has started to drop and I can’t reconnect it for some time. I have rebooted the tv which restores the WiFi but then it disconnects eventually and I have to reboot it again.
Any my ideas why this is happening?
Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
joelippa
Member
I have no idea what a XF438505 is but there's a lot that can go wrong with WiFi i.e. distance, interference, intermittent issues caused by nearby devices / nearby networks etc.
Unless you have some concrete reason that forces you to use WiFi, connect your boxes with cables.
1 REPLY 1
joelippa
Member
