Sony DPF-E72N.
SOLVED
Sony DPF-E72N.
First of all i apologize if this is the wrong forum to go too. Could anyone please tell me what memory card i need to buy to put into the photo frame of the above gadget. Thank you.
      And also do i need anything else other than the memory card to get it to function properly. Thanks again.
  Ray.
1 ACCEPTED SOLUTION
Accepted Solutions
Anonymous
Not applicable
HI there
According to the Specifications : HERE the compatible memory cards are:
  • MS
  • MS Duo
  • SD
  • SDHC
  • xD
See Pages 56 of the manual onwards : HERE
You dont even need a memory card as it does have some internal storage capacity.  You just need a USB cable (Type A Male to Type B Male - same as a printer cable)
No other equipment that you will need
Cheers
1 REPLY 1
Anonymous
Not applicable
HI there
  • MS
  • MS Duo
  • SD
  • SDHC
  • xD
Cheers
