Z1 battery issue?
SOLVED
norwegain_magpi
Visitor
Z1 battery issue?
Hi all,
This happened:
After I picked up my phone in the morning (from charger), it had turned itself of during the night. After using it a while it started rebooting itself. This occures now very often. This happens with a lot of battery % left. Sometimes it restarts, and sometimes it just stops. When it stops I have to put the charger in to restart it, even it the battery seems to be fully charged. Can be an issue when I`m not at home. Slightly_smiling_Face
I have notised that the battery % varies sometimes. It can co from 4 - 100 % in minutes while connected to the charger (Sony charger)
I have tried this.
- VolumeUP/Home button.
- Red button in Sim slot.
- PCC resetting
The phone was upgraded to Lollipop about one month before this occured. Have been working fine after the upgrade.
Can this be an battery issue?
Kristian
14 REPLIES 14
norwegain_magpi
Visitor
Hi Sotonion. Yes, it's waterproof and sealed. But you can use a hairdryer or a heat gun to get of the backcover. You can find a lot of videos on YouTube. And you can find New batteries and new seals on ebay cheap.
https://youtu.be/Io9jHfs6z94
bigviv
Visitor
so it's up to us to crack open the phone and replace clearly defective batteries? I'm now using an old htc one x where the battery is still going strong, because i can no longer rely on the z1 due to the issues everyone else is having with the battery
where's the accountability here?
norwegain_magpi
Visitor
It's up to you if your warranty has expired.
Abhi16
Visitor
Factory reset will work. Because when you upgrade to lollipop it doesn't install all its Api's properly. So after factory reset it installes lollipop properly and then battery issue will get resolved
AndyCox
Visitor
I too am having battery problems and it's out of warranty but being a sealed unit how do you change battery? Phone still working brilliantly on android 5. Seems a shame to sign up for a new phone.
