Strange Settings problem
SOLVED
makhijamm
Visitor
Hi !!
I am having this strange problem. When I restart the phone for first 2-3 hours if I click on settings it asks for security password. Although after 2-3 hours it stops asking for one but I am sure I havent set any passwords. The default passwords like 1111, 0000 etc wont work. I mailed sony care but there response is still pending. I dont wanna reset phone and spend time setting up all the things again Slightly_frowning_Face . Can anyone suggest a solution? I am attaching a screenshot of the same.1387789_10151608599187257_1494484467_o.jpg
1 ACCEPTED SOLUTION
Accepted Solutions
SonyBridge
Visitor
Hi, I was having the same problem with my z1 and I had to reinstall the firmware using Sony Bridge for mac after that it's working fine no problems whatever .
15 REPLIES 15
Uliwooly
This is odd, do you have a SIM lock? is it a PUK password/pin?
makhijamm
Visitor
Nope... No lock. And if there would be one then why just for 2-3 hours?? Slightly_frowning_Face
Uliwooly
You might have to reset your phone, you have to use SUS
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
for future reference
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
SonyBridge
Visitor
Uliwooly
Glad to hear it worked for you
makhijamm
Visitor
Can you help me with the process?? how can I avoid re-downloading heavy apps??
Uliwooly
Just read the steps above, you will have to redownload all your apps
Sandy7199
Visitor
So did the problem get solved or you had to download everything again? Am facing the same problem though in my case it asks for password all the time
Sam
Legend
Legend
Have you tried the steps outlined by Uliwooly? If the phone is locked and you can’t get in you will need to run a repair as per the steps provided above.
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
