sony xperiaz charging problem
cavita
can i charge my sony xperia z in laptop for 30 min after unboxing???? no two pin plug in here soo
Tags (1)
Thommo
Yes absolutely fine - You should have a battery metre informing you of the charging status
5 ANTWORTEN 5
Thommo
As long as the output is 5v which it is from a Pc/Laptop then you will be fine but charging will take longer - As for your power plug you will need to contact the place of purchase about this
cavita
 im gonna keep it more than 30 min then...??its fine to charge on laptop for the 1st time?? i mean dosent make differnce from laptop or power plugin?
Thommo
cavita
yeahhh!!! it has been more than hour been charged...& my notification light has been orange from red...that means>???
Thommo
Battery notification light status
GreenThe battery charge level is greater than 90%
Flashing redThe battery is charging and the battery charge level is less than 15%
OrangeThe battery is charging and the battery charge level is less than 90%
