Solved! Go to Solution.
It might be something faulty with your SD-card. Have you tried to format your SD-card to see if this can help? Otherwise, I would suggest that you try another SD-card to see if the same thing occur.
128GB means probably the card is UHS I or II,over class 10 so there shouldn't be any problem.You could try a low level format.
This is strange,I suggest you check if the phone detects the card in safe mode:
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
This is strange,maybe you could stop by a sony service and have the device checked?
