Hello,
I've tried the nfc sharing from z3 compact to z3 compact and it havent worked for at leas one time, it doesent even turn on bluetooth when it should transfer the file. Both phones discovers each other, but when i select the content to share it kinda starts to work, but never buffers any percentage of the file.
Both z3 compacts worked with every other phone i've tried, but not with each other. What is the problem? Is it some kind of a software bug? I have tried to rename both devices, still no luck.
Thank you for help
Solved! Go to Solution.
