hey.
just woke up after charging to phon all night and the back and home button not working everthing was fine before, what can i do?
Hi @ygeisler and welcome to the forum!
Sorry to hear that. Can you try to force the phone to shut down and then turn it on again? To force a shut down, press and hold the volume up button and then power button at the same time until the phone vibrates (should take about 10 seconds). When the phone is turned off, restart it.
Are you now able to use the home- and backbuttons?
Hi ,
d
I suddenly have similar problem on z5 dual. My Home and recent apps buttons doesn't work. Tried force restart as suggested but no help there. Request for a suggestion.
Thanks!
Naresh Eluri.
I'm sorry if I missed that part.
What you can try to rule out this being related to software or not is performing a software repair using Xperia Companion.
Even though there isn't any visible damage it's not impossible it's related to hardware, especially if you cannot clear the bottom part of the display in Diagnostics. Contact your Local support for information on how your device can be sent to an authorized service centre.
