Translation via Google Translate:
The n j u buttons of the keyboard stopped working and pressed the keys on the sides of each one of them and that happened suddenly please help some solution or it could be configuration or if the touch is damaged any suggestion will be welcome thanks
Los botones n j u del teclado dejaron de funcionar los presionó y se activan las teclas de los lados de cada de uno de ellos y eso sucedió de repente por favor ayuden alguna solución o pueda que sea configuración o si se daño el táctil cualquier sugerencia será bienvenido gracias
Hi @Davigires;
Please post your subject in English as this is an English based forum and for everybody can help you.
Test you touchscreen in Service Menu (dial *#*#7378423#*#*) under service test.
Test also the behavior in safe mode.
