Flashlight and torch problem
ADemart
Visitor
Hi everyone,
There is the problem appeared with Xperia Z5 Dual. Flashlight and torch stop to work after flashlight is used for the first time. After that camera works as it should but no flash and the torch doesn`t work. After reboot it`s possible to use flash again but only once. Service test gives the same result. Safe mode also. Moreover the phone was flashed by Flashtool recently  - no changes.
Any suggesions?
Thanks.
0 REPLIES 0
