My display of sony xperia z was broken. Now the upper glass is divided into two sides & only one part of it is working & other part ain't working. but i am also able to see everything & every notification or display things are as the first day i bought it. Now i am wondering is my display broken or the touch screen?? and also my headphone mood ddoesnot turn of when i remove the headset from the phone. Please help me with solutions of the problems.
Solved! Go to Solution.
Well I can't help fixing your screen but if the screen looks fine then it's probably just the touch pannel damaged - You could connect a USB OTG cable and then use a mouse to control your phone - To have it repaired contact Xperia care http://www.sonymobile.com/gb/support/contact-us/ - As for the other issues then you may need to peform asystem repair
