I currently have the z5 premium and want to upgrade. Should I go for the xz1 or the xz premium?
@Ola40the phones are quite similar spec-wise (as can be seen here https://www.phonearena.com/phones/compare/Sony-Xperia-XZ-Premium,Sony-Xperia-XZ1/phones/10443,10277), except for XZ Premium rendering some of the apps (Album, Videos, Youtube, Amazon Prime Videos) in 4K.
XZ Premium has got a higher battery capacity (3230 mAh compared to XZ1's 2700 mAh), which is to be expected, as XZ1 is a bit smaller.
there's also a difference in materials, XZ Premium has got a back made of glass, whle XZ1's back is made of aluminium.
another difference is in size, you can compare the size of XZP and XZ1 here: https://www.phonearena.com/phones/size/Sony-Xperia-XZ-Premium,Sony-Xperia-XZ1/phones/10443,10277#/ph... I've also added Z5 Premium so that you can get a general feeling of how they compare in size to your current phone. you can press "view side by side" button if you want that kind of comparison instead of layered one.
Thanks. Will check it out. I have read alot of comparisons bit still not sure... Quite used to the z5 premium and think it's great just hope the xz1 doesn't feel to small in comparison. I watch a lot of videos and use the camera loads so in one way the xz1 is better in another the xz premium.... My head is a mess!
