Goodmorning everyone,
I recently purchased the Sony Xperia XZs, after the first boot the device was blocking and now it does not turn on, I tried to recover from Xperia Companion but it came out written this "the software update failed to make sure that your phone is connected to the computer and try again "and recovery does not go well, it reaches 10%, do you recommend what can I do? I've tried them all.
Thanks, waiting for response.
Hi @SamueleOne, welcome to the community.
If Xperia companion is not working correctly there are a few steps that you can try to resolve this.
Try these methods one after the other. Verify after each method whether the problem was solved, before trying the next one.
Good morning and thanks for the answer,
I tried everything you wrote to me but it does not go anyway, and now that it is unloaded, when I charge it, it restarts continuously and can not load.
See if you can complete a software repair using Xperia Companion. If not, then I recommend you contact your Local support team to arrange an assessment of your device.
