Wifi, screen rotation, speaker Bugs
Aviv982
Visitor
Hello Sony.
I have an Xz2c and from the start I have these issues. Had factory reset.
The wifi issue is a most annoying for me, because I am a network technician and I am a very experienced in this. So the wifi bug is:
When using wifi scanner applications , several seconds is working fine but after that, it stops to forward the teceived beacons to the api/apps.
The phone is running the latest Android 9, the 202 build, the issue appears from android 9, and previously had similar issues with android 8.
No one responsible to fix it?
5 REPLIES 5
CrimpOn
Visitor
I do not observe this with WiFi Analyzer by Kevin Yuan.
profile.country.NL.title
Strampke
Hi @Aviv982
Problem solved?
What if:
- you do a software repair using Xperia Companion.
- just install the most urgently needed apps
Does it occur than too?
Aviv982
Visitor
Hello All,
This problem is here about year.
Tried full factory reset with companion app on pc without backup. After that installed only the wifi analyzer and the issue is still here.
I'm tired of trying to solve the problem.
Aviv
Strampke
@Aviv982
Which WiFi analyzer apps are you using?
