Network not available seems battery lower than 50%
Ryan1314
Visitor
Following problems unexpectely occured every day from 3rd March.
1. Can not receive nor make phone call.
2. Show 3G symbol instead of 4G and internet is not stable
3. Show "No network available"
So far I can not find the pattern for problem reproduction.
But, I found that above problems easily happend afternoon,
especially battery lower than 50%
Xperia XZs
System version: 41.3.A.2.220
#Xperia XZs
3 REPLIES 3
Kulveer
Visitor
I have same problem from last week.
I did hard reset and also did *#*#4636#*#* network settings but no solution.
Sim changed but same problem, all SIMs works well in other mobiles.
I contacted 3 Sony service centres, but they told they only handles software problems ( Which I already did hard reset by PC companion with Volume Down Key press) not hardware, so they don't inspect.
My mobile is 15 months old so out of warranty. No service centre do hardware repair, they told me swap your mobile with Xperia xz1 by paying Rs 14000.
Very bad service if company don't repair there products who will did ?
Ryan1314
Visitor
Hi Kulveer,
Thank you very much for your comments.
Your experience is totally same with mine.
I tested SIM card using other mobile and reset to factory initial status.
Also sent to service center, but got same feedback like you.
Staff of service center told me that my main board is damaged and out of warranty.
I could choose to replace new main board or upgrade to other new model.
No matter which one I choose, I have to pay high amount almost buying new one.
Kulveer
Visitor
Did they open your mobile, tested it and then told pcb board problem?
