Xperia sp touch screen problem
dhineshdc
Visitor
I bought xperia sp on August 10. I have the latest update from sony. But still,I am facing problem of touch when i keep my phone on any flat surface. Also some times when i press power button to unlock, the screen does not come up.
Does Sony doing anything to fix these 2 issues in next updates.
7 REPLIES 7
Uliwooly
This might be a hardware issue, take your phone to a Sony repair center ASAP
Ashroft98
Enthusiast
Dhineshdc,the touch problem ob any flat surface is actually a glitch.You can take it to Sony Repair Center.And for the lock screen not coming up.Its a softwate glitch,even i face it.All of us face it.Just wait for the 4.3 update to roll and fix these problems.
shams1924
Visitor
I have the exact same issue. i got the latest software update as of right now.
when phone is flat, touchscreen only responsds 10% of the time.   happens when also in a cradle or when the phone is not moving.
i hope this issue is to be adresssed on the 4.3.   somehow i dont think it will be
antonidas
Visitor
flat surface problem is easy.
Just restart your phone.
omarkam
Visitor
I have the xperia sp with the problem where the touch screen stops responding while the phone is plugged in the charger. I also have the xperia GO. I connected the sp to the GO charger and the problem went away away.
baturyucesan
Visitor
I accidentally find that when your finger of your either of your hand is touching the metal surrounding frame of the phone touch screen responses correctly so it should be a hardware problem maybe static something.
dosi
Visitor
When using my phone touch is not work in normally...it works in hard touches only....then i restart the mobile touch works in normal way...please give me the reason of the problem and is it a hardware or software problem?
