WiFi issues
hi_
Visitor
WiFi issues
"unfortunately captiveportallogin has stopped" Can not login to the wifi network
6 REPLIES 6
Uliwooly
@hi_
Are you using a custom ROM? rooted phone? etc
also check this out
https://www.reddit.com/r/AndroidQuestions/comments/32kyxk/captive_portal_login/
hi_
Visitor
No. am using 5.1.1 & its not rooted
Jake-SonyXperia
Champion
Hi hi_,
Welcome to the community,
Can you boot in to safemode and advise if you still get the error message or if you can access Wifi?
Safemode
hi_
Visitor
Downloaded the app "WiFi after connect" it solved the issue...
DJ26
Visitor
The user name is also case sensitive.
