Wifi and GPS randomly turning on and off
LukaLuxXD
Visitor
It's really annoying, does this happen to just me? How can I fix this?
8 REPLIES 8
profile.country.RO.title
_alexdon_
Do you have stamina enabled?
alexdon
LukaLuxXD
Visitor
Yes, I do.
I noticed when i unlock my phone WiFi turns on and off.
_alexdon_
That might be due to the option to keep wifi on during sleep.Stamina will try to stop it while the screen is off.
alexdon
ellusive123
Visitor
It has nothing to do with stamina. I got stamina scheduled to run when battery goes below 20% and wifi goes randomly off/on all day long. It's a software problem. Same thing happens with signal. Not much you can do about it, but toggle on/off wifi from settings shortcut.
_alexdon_
Did you check if stamina actually enables at 20% or is on all the time?
alexdon
LukaLuxXD
Visitor
For me its always on
_alexdon_
Just disable it and see if the same occurs.
alexdon
ellusive123
Visitor
Stamina is off untill battery goes below 20%, after that it activates, it's useless anyway, because I don't see any diference between ON/OFF. The wifi/gps if activated/ signal problems are not from stamina. I think it's a software problem. My gf has same issue on her device XSP also. On my other phones i have no issue with signal or wifi or gps so it must be software problem.
