W508 problem: irregular light flashing
Not applicable
Hello everyone,
I have a little problem with my Sony Ericsson W508. The little blue light next to the camera on the outside of the housing sometimes flashes for no reason.
I write a message, lay the phone down - and it starts. When I open the device and close it, it doesn´t switch off, it still illuminates. As it is pretty bright, this is annoying. The only thing that helps is to power-down the phone and switch it on again. Sometimes this has to be done twice.
Does anyone else know this issue?
2 REPLIES 2
KrazyD
Contributor
Try updating your firmware with Sony Ericsson Update Service to see if this solves the problem.
Not applicable
Thank you! I will try this.
