please tell me one thing if i am disconnecting my phone during the update so is this any major problem?.
Has the update completed?
Don't worry
Charge the phone with a wall charger for an hour > restart the whole update process again
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
If you need the steps: performing a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Make sure the device is not connected to computer or laptop and turned off (sometimes you have to press power button and volume up until the device vibrates 3 times or on some devices you have to press the small button near the SIM tray or on the back of the device).
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable. If PC companion does not start the repair process, you might need to run it in compatibility mode with Windows 7 (in some cases XP).
