i put an sd card in my tablet,now i get a warning saying my internal storage is at 75 per cent.but when i go to settings and try to transfer pics,music etc to my sd card ,you cant ,nothing happens.please help,is there a way around it or an app to help,something easy.cheers john
You have to clear apps,it means you did not make enough space with the pics and music.
Try using the File Commander application, you should be able to Cut them from the Internal memory to the SD card.
Apparently it's a google, kitkat problem and all my research suggests there's no real fix, so I'm pretty pissed off.
If you have a lot of music and pictures in internal memory try to move them to SD card using File Commander.
If your memory is clogged by lots of applications and their cache you may try to remove some apps, clear cache (for music and video apps - like Spotify off-line).
Unfortunatelly starting from 4.4 KitKat Google locked out possibility to move apps to SD card. Maybe Sony will port this feature back as they did with lower spec phones but I wouldn't expect it to happen before Android L release if any.
I think they will work hard to move Z2/Z3 flagships to Android L at the end of the year with Z1's to follow and maybe then will think about this feature (but that's are only my own opinions).
