Heating problem
Arlyn
Visitor
Heating problem
I just bought my XA1 this week, everything is running smoothly, the only issue is it overheats, I'm just using my facebook and no other applications opened, sometimes i play clash of clans but after playing i always ensure that it is closed, i just want to know if this is a issue or it is normal? In facebook sometimes i watch videos but on an average of 8mins only. I hope someone helps me, thanks
5 REPLIES 5
Uliwooly
@Arlyn
Even when you close an app, some will continue running in the background, facebook it is known to be a heavy battery hog app, it will drain your battery faster and heat up the phone; the phone can't overheat, as if it gets too hot, it will shutdown to prevent any damage.
Arlyn
Visitor
Thanks for the reply, i have one question, is it normal to heat up while charging even though it's turned off?
Uliwooly
@Arlyn
Yeah, but it shouldn't heat up a lot, unless it's a really hot day it might have an effect, which wallcharger are you using?
Arlyn
Visitor
It's heating up like I'm playing some games, im using the original charger of my xa1
Uliwooly
@Arlyn
which games?
