Yep,I had this issue at the beginning too,it gets so hot that the phone wont be able to charge properly and instead of charging it drains out quickly also the phone will warns you that the phone is not charging properly,after I rebooting the phone it start charging normaly again but later the same issue happened and I notice that there is an app is the cause of that and drains the battery very quickly so I removed it and the problem fixed ! the app was mombogeine lol.
how ever restart your phone and see if anything changed , or check your apps ! :smileysmileythumbsup:
