Delay on calling
NVA
Visitor
Delay on calling
Hi
I am using Xperia S. LT26i model. Now days while making calls it takes time to dial the numbers. I have tried clearing the cache and I do have space of 21 GB left in the mobile. Checked for the latest software update and got the message as my phone is updated with the latest software.  I am using Clean Master app  to boost the memory. with few sms and contacts less than 200 numbers.
Please advise the solution for the above.
Thanks in advance
NVA
3 REPLIES 3
Johan
Master
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
I suggest that you to run your phone in safe mode for a while to check if you still experience this. If not this may be caused by any downloaded application.
How to boot into safe mode?
Let me know how it goes.
NVA
Visitor
Hi Johan,
Thanks for the help.
As per the suggestion,  my phone was in safe mode. While on safe mode there were no games and other application which are downloaded, and my phone was bit ok. However in the normal run with all the applications on screen, facing the same problem. As you have suggestion this problem may be by any downloaded application, I would like to know is there any way to find out which application is causing the problem..
Please advise,
NVA
Johan
Master
There is no easy way of finding out. But I suggest that you first check which call related applications you have installed and try to remove those and test again. If it still happens you will have to continue to remove other downloaded app's one by one.
