Contacts Outlook Sync problem
samirmorgan
I have a new Xperia M, and I tried to sync contacts with outlook 2007 using Sony Pc companion, the problem is that I cannot choose which outlook contact folder to sync,  It just chooses a window contact (1011). I need to choose which  contact folder to sync.
Rickard
Meister
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
When you open Sync Zone in PC Companion you should have a dropdown list next to Contacts where you can select Outlook instead of Windows contacts.
If you only see Windows contacts there it seems that PC Companion is unable to detect that Outlook is installed in your computer. In that case, is Outlook installed locally on your drive or are you running it remotely?
