I recently tried to update the firmware on my x10 and I now get an exclamation mark on the screen. How can I fix this?
Try running the update again or flashing the phone manually using omnius.
Thanks KrazyD. The issue is I cannot connect it to my PC as I cannot access the phone. When I try it says no phone connected and I look in the different drives on the PC and it does not show. How do I get around that when I have the yellow exclamation mark?
I think you have to do the update/repair using the Update Service. Just follow the instructions the program gives you, then if it tells you you have the latest firmware, it should give you an option to Repair your install. Select that and just follow the prompts the program gives. Hope this helps!
