hello everyone !!
my Sony Xperia ZL (C6503) is completely discharged after sudden on/off (15-20 times) causes by software issue and after that i plug into charger but there is no charge or even notification led turn on look like a dead phone:smileydrooling:
even i try press volume + key and power key holding method but it was not help.
please give me some suggestions.
thanks
Which phone model do you have? If the battery is completely flat, it can take a longer time before it indicates charging or powers on. I suggest that you connect the phone to the charger via wall socket and let it charge for 2-3 hours to see if it powers on afterwards.
Sony Xperia ZL
Hi aman7071,
Try holding the Power Key and Volume + like you did before and then immediately plug in to charge, generally the device will power on about an hour or two in to it.
