completely battery discharged
aman7071
Visitor
hello everyone  !!
my Sony Xperia ZL (C6503) is completely discharged after sudden on/off (15-20 times) causes by software issue and after that i plug into charger but there is no charge or even notification led turn on look like a dead phone:smileydrooling:
even i try press volume + key and power key holding method but it was not help.
please give me some suggestions.
thanks
Tags (1)
3 REPLIES 3
Hampus
Champion
Which phone model do you have? If the battery is completely flat, it can take a longer time before it indicates charging or powers on. I suggest that you connect the phone to the charger via wall socket and let it charge for 2-3 hours to see if it powers on afterwards.
aman7071
Visitor
Sony Xperia ZL
Jake-SonyXperia
Champion
Hi aman7071,
Try holding the Power Key and Volume + like you did before and then immediately plug in to charge, generally the device will power on about an hour or two in to it.
