Can't unlock my phone! Help?
j_rhodes224
Visitor
One of my friends set up a pin pass code on my Xperia E (without me knowing). He also set the security question to place of birth and I dont know what he set the place to. Whenever I try to put my google account details into my phone it says incorrect. He says he doesnt know what the pin is. Does anybody know how to bypass the pin even if it means deleting all files on my phone.
1 REPLY 1
Thommo
Try to perform a system repair
Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds)
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP
