I Bought the phone 2 days back and observed the camera button on right side is not working properly. I have to literally press so hard to switch it on.
Is their any fix for it.
I tried doing factory reset.
Thanks,
Rohit
Hi Rohit,
You just remove the back cover and see the right bottom side panel,there you should be able o see actual camera button check whether pressing directley on that button is working or not,if it is working then it might be back panel alignment issue.One more thing you can try is lock the phone and hit dedicated camera button,camera should be activated within 1 sec as per SONY's sdvertisement.
PS:The camera buton provided on side panel is not a feather youch button,normally one should do a gentle press to activate camera and hold pressing for long time(2 to 3 sec) to capure pictre.
Hi Gopish,
You are right it is working as you said. I have to press and hold for 2 to 3 sec to get the Camera active. I taught it was problem only for me is everyone facing the same issue.
Is their any way i can reduce the delay.
Thanks,
Rohit
the same problem happened with me.It is not working even if i hold for more than 10 sec and so.
Is there defect in handset or there is any setting to activate this.Please reply
Hardware design
We used to capacitive touch and feather touch, so pressing the button seems hard for us
