Batter drains while charing. HELP
Jannwong
im charging my phone and video calling at the same time. My phone drains faster that it charge!
its a serious issue because most of the phone dosen't have this problem. please advice
60 ANTWORTEN 60
Jannwong
ok. i'll try and keep you updated. thanks!
profile.country.RO.title
_alexdon_
Good luck.
alexdon
Jannwong
No luck :(.
The problem is still there. any advice?
Jannwong
The SUS formated my phone and stuffs are kind of messed up such as my alblum (dint get the latest update and i cant get it form the update center) and also my keyboard ( dint get the latest update). what should i do?
_alexdon_
You should be able to get next updates from update centre.That is why I suggested a clean install from SUS,I thought it will work.Still the same?
alexdon
Jannwong
yes its still the same. what should i do?
_alexdon_
Stop by a sony service.I am really sorry.
alexdon
Jannwong
its ok. i will go check with the service center.
thanks for helping me out Slightly_smiling_Face
_alexdon_
Anytime.Keep us updated.
alexdon
Shadow93
This happened to my sis phone too *Xperia Z*
the reason is that one of the program you're using is cuasing that,  probably the app draining the batter faster than it usual condition I got a way to fix my sis phone so try one of these two options they fixed my sis phone
1-restart your phone normaly
2- if the first option did not help then try this Hold the power button and the volume + button togather at the same time for 3-5 sec the phone will vibrate 3 times and restart the phone automaticly this should help if its not then I suggest you to check the service center or just reset your phone ^^;
best of luck for you! :smileysmileythumbsup:
