Flash problem
Damstline
Flash problem
 In the photo there are green stripes on the side of the flash. Is it a malfunction or unreasonable construction?JPEG_20171225_131657_82322430.jpg
8 ANTWORTEN 8
profile.country.NL.title
Strampke
I have found something on Google here
and here.
psr323
I also have this annoying issue. In complete darkness, if I capture a pic with fill flash there is a considerable amount of greenish flare. I am sure it's not normal. 😞
Strampke
@impk
Did you read my post?
It is explained in these links.
Just click on it.
psr323
@Strampke
Yes I did. But aren't the flares mentioned in those links from external sources? In my phone it  happens because of phone's own flash light. Isn't that unacceptable? 🤔
Strampke
Try to figure out what is the cause.
Read carefully, change circumstances to find out how to eliminate the flares and you will have successful photos afterwards.
c01nd01r
+1. date of assembly 11-2017.
AlexUnder20101
The same problem, white F5122, Oreo, date of assembly 10.2017.
c01nd01r
