Hello everyone,
We recently noted that some TVs of the series KDL-xxEX, KDL-xxHX and KD-84X9005, that went on sale in 2012, will reboot in a loop after internet content has been refreshed ending up with a blinking LED. To avoid this symptom please disconnect your TV from the Internet until this issue has been fixed. To do so please disconnect the LAN cable, unplug the Wi-Fi Dongle or disable Wi-Fi in the settings of your TV.
If you're already affected by this problem please use one of the following workarounds:
1) In case of Wired LAN connection:
2) In case of Built-in Wireless LAN connection:
3) In case of USB Dongle Wireless LAN connection:
This issue is currently under investigation and we hope to have it solved soon. If you face this problem please reply in this thread.
Thanks a lot for your understanding
Your community team
Solved! Go to Solution.
