Replacement cable for headphones wh-1000xm2
SOLVED
Tezes.
Explorer
Hi all, can anyone recommend a replacement cable for my headphones please.
They have just started to let me down with the sound only coming out of the L side unless I press the port (hard to explain).
I have asked at curry’s where I bought them but the cable they recommended didn’t work in that no sound came through at all !
thanks in advance x
1 ACCEPTED SOLUTION
Accepted Solutions
Joe_Dohn
Specialist
Has this solved it for you @Tezes ?
It'd be really helpful if you'd let us know and mark the thread as solved so others can find the solution easily!
- JD
5 REPLIES 5
Bat_Rick
New
Tezes.
Explorer
Thanks 😊
Sent from my iPhone
Joe_Dohn
Specialist
- JD
Tezes.
Explorer
Spoiler
Yes thank you.
could I also ask if the headphones can be charged from the mains via my plug adapter, rather than having to set up my laptop - thank you
Joe_Dohn
Specialist
