MacOS (Catalina) and WH-1000XM3 Connection Issues
kasmond0
Explorer
Hi all,
I have update the iPhone 6s and the MacBook Air (MBA) (Early 2015) to Catalina.
If I am connecting to either devices (not both at the same time), what I am observing the WM-1000XM3 is disconnecting after a while. What is wierd when I go into bluetooth settings it shows the XM3 are connected. What happens when it disconnects no voice is coming out of the XM3 and all of it now coming out of the speakers of the device (iPhone or MBA). It is quite funny, but not so funny when on the train full of commuters whilst I listen to dance music or at home or shopping...
What I do to remedy this is I reconnect by disconnecting and reconnecting again the XM3 on the iPhone (or MBA).
It is annoying as the frequency of disconnection happens sporadically and not consistent.
I have reset the Bluetooth driver on the iPhone and MBA back to factory defaults. No improvements.
I have been into the Apple Store and spoken online to Apple, they have pointed me back to Sony.
Anyone else experiencing this?
21 REPLIES 21
profile.country.DK.title
AskAgain
New
Hi. I'm glad you posted this. I have the same issue with my WH-1000MX2 headphones.
qexpres
New
Yes! I am experiencing this problem on my MacBook Pro. Deleting the Bluetooth plist file and resetting NVRAM/PRAM on my MacBook Pro didn't help. I'm not entirely sure whether this a Sony or Apple problem; I just bought my headphone. Also, my Apple keyboard sometimes disconnects and my colleague recently disconnected with his AirPods from his MacBook. Both incidents don't happen as often as the issue with my Sony headphone, though.
I didn't experience this problem on my phone yet, but I also use it less frequently for listening to music.
Headphone: WH-1000XM3
OS: macOS Catalina (10.15)
Computer: MacBook Pro (13-inch, 2016, Two Tunderbolt 3 ports)
profile.country.IT.title
rooobb
You may check via the app if they are configured to turn off automatically
https://helpguide.sony.net/mdr/hpc/v1/en/contents/TP0001970071.html
qexpres
New
Turning off didn't work. It's like kasmond0 said: it happens sporadically. Also the headphone won't turn off when it happens and the connected device (MacBook Pro in my case) acts like it is still connected to the headphone. However, the audio can't be heard from the headphone anymore and the "connected" device will start playing audio from its own speakers instead.
joej03x
New
Same here: It happens randomly, worked fine with High Sierra and occurred after the update to Catalina.
Probably some sort of driver or firmware issue...
profile.country.US.title
Rocky_Raccoon
Explorer
I was having this same exact problem when connecting to my early 2015 macbook pro catalina v10.15.1
I recently updated my headphones to v4.2.2 and Ive stopped having the issue
daniel.petrovaliev
New
I followed this guide and it fixed my problem with changing output device.
https://www.ikream.com/how-to-fix-problems-with-bluetooth-on-macos-catalina-36499
kasmond0
Explorer
No - that does not solve the issue.
sdfsdfsdaasdfgasdfa
Explorer
I contacted support after trying all the obvious ways and got this reply
"We are sorry to inform you that the device you are using is not compatible with the headphone, hence you may encounter any issues while using the product as we can only guarantee functionality of compatible devices."
If this is true then it is absolutely ridiculous. I don't know whose fault it is Sony's, Apple's or both but you expect a £300 pair of headphones to work with the latest version of a major operating system.
