screen resolution
jonmerc
screen resolution
hi can anyone help my viao laptop screen is really bright, the green light is on all the time but when i try to turn it down nothing happens how can i fix this please. regards jomo
8 ANTWORTEN 8
Thalamus.
Champion
Hi jomo,
have you tried pressing the FN key and then the F5 key.?
jonmerc
hi, yes i have tried that the icons are jumping when i do it but the screen has not changed regards jomo
Thalamus.
Champion
Hi Jomo,
what model Vaio do you have.?
Are you using the Sony supplied OS.?
Do the FN keys work when Increasing or decreasing the volume.?
jonmerc
hi Thalamus, i have a vgn a297 xp no the green light is on but the volume up and down is not working either, the mute light is coming on if i try it regards jomo
jonmerc
yes it is the sony os
Thalamus.
Champion
Hi Jomo,
download the Original Utilities Package from Vaio-Link, Use the following link: Sony Vaio Support Original Utilities Package
Once downloaded extract the files and then install the following, in order.
1 Sony Utilities
2 Sony Shared Library
3 Vaio Event Service
Once completed then re-boot your Vaio.
You may have to do this more than once..:smileywink:
jonmerc
hi Thalamus,
worked a treat first time thank you very much. regards Jomo
Thalamus.
Champion
You're welcome Jomo.. :slight_smile:
