need to get data off my hard drive
martinh
Visitor
My VGN-S3XP has developed a fault and will not load XP..error flashes on the screen (so quick I cannot read it clearly) but says something about registry error.
My latest book is on the harddrive (not backed up!) does anyone know how i can get the data off the hard drive?
Many thanks
Martin
9 REPLIES 9
seb21__
Visitor
Try to start your vaio in save mode. Click the power button an click a few times F8. then start in save mode. If it works then try to backup your book from there. After that start with the last windows restore point.
Hope this helps.
martinh
Visitor
thanks...have tried, but wont even boot in safe mode
seb21__
Visitor
test
profile.country.en_GB.title
kee-lo_
Member
Have you tried making a boot disk with NTFS for DOS from bootdisk.com?
martinh
Visitor
No i havnt..just had a look at the site and completly lost?
What do i need to download and how do i use it?
Martin
seb21__
Visitor
You could aslo try to boot via network. Or connect the harddisk directly to another PC. You should be able to read and save the files then. Maybe the PC store in your near is able to do that.
martinh
Visitor
Took out the disc, but it is sata and my other pc's are ide
Thanks though
seb21__
Visitor
Hmmm, thats bad. I don't think it makes sense to buy an converter.
kee-lo_
Member
A converter is the best bet
