MYCLUBVAIO TROUBLE
dieghino77
Visitor
MYCLUBVAIO TROUBLE
Hi all,
when i click on myclubvaio icon on desktop a popup opens but nothing happens... it just shows a blank popup! what's wrong with it?!? some plug-in not working???
16 REPLIES 16
MattWilson
Visitor
Right click on it and click run as administrator.
Thalamus.
Champion
Hi dieghino77,
welcome to Club Vaio.. :slight_smile:
I have sent you beta fix via a PM, please click here to read your message..
Please provide feedback as per the message.. :slight_smile:
Porsenna
Visitor
I have the same problem: what can I do... can you send me the same fix?
Thalamus.
Champion
Hi Porsenna,
Sent you the fix via PM, please click here to read your message..
abercellini
Visitor
Hello Thalamus,
I´m having the same problem with MYClubVaio and it´s incredible annoying. May I ask you to send me the same beta fix?
Thank you very much.
Thalamus.
Champion
Hi abercellini
You can download the new fix via the thread Do you have an error message 'Please connect to the Internet to download the latest version of My Cl...
abercellini
Visitor
Hi Thalamus,
Thank you very much for your help.
Unfortunately I´ve deleted MyClubVaio so now this patch says that wont work. Do you know anyway to eliminate this MyClubVaio Pop-up that is no related to format computer and reinstall vista with the Vista Recover DVD?
Is there anyway to get just the original MyClubVaio.exe from the Vista recover utility DVD?
Anyone who is posting the .exe somewhere on the net?
Maybe an specific pop-up blocker just for this insufferable vaio´s design mistake?
Thank you again,
Best!
Andres
Thalamus.
Champion
Hi abercellini,
You should be able to stop My Club Vaio.exe from starting if you go to start > All Programs > Accessories > System Tools > Scheduled Tasks..
In task scheduler go to the bottom section of the centre column (it should be called active tasks)
Double click LaunchMCV and in the new window select delete... :slight_smile:
MattWilson
Visitor
Hi Thalamus,
Thank you again,
Best!
Andres
Start -> Type "Task Scheduler"
In the window on the left hand task plane click on "Task Schedular Library" and disable all of the MCV entries and you will no longer have the pop-ups :slight_smile:
