annulla
Cerca invece
Intendevi dire:
Finger Slider
drali
Visitatore
Finger Slider
I've recently changedmy Vaio from a FS series to NS series, specifically NS20
I am so use to using the finger slider from the top-left of the touchpad that I am missing it on the new vai which has tap zones instead. Is there anything can do to get it the finger-slider back on.
Just for info:
The finger slider from the top-left of the touch pad allows you to minisime, maximise and close windows quickly
2 RISPOSTE 2
Blencogo
I take it you have looked at the Touchpad Properties and cannot find this feature.
The problem is that the NS20 has a Synaptics driver where your FS had an Alps driver and the feature you seek is probably not available without installing a different driver.
:thinking:
drali
Visitatore
Had a feeling that it might be a manufacturer thing, Thanks as always :wink:
